K
KNIPEX
Hi guys, ive taken a main bond to the gas pipe which is in steel as its a commercial job, where it enters the property, which also has a gas shut off switch there. however the pipe then runs 15-20m inside the building where it connects into a gas meter still inside the building.
it then runs around the building from the otherside of the meter.
so really i have bonded the incoming not out going, its a strange one.
i was thinking of putting a link acoss both pipes just above the meter so the outgoing is bonded too.
what your views and advice on this please??
