Strange fault - larger cable tripps mcb ????? Why ??? | on ElectriciansForums
Discuss Strange fault - larger cable tripps mcb ????? Why ??? in the UK Electrical Forum area at ElectriciansForums.net
djjeff99
Hi There
I have a very strange one here , that no one iv asked seems to know the answer to .
On a recent test i found a 6mm XPLE SWA cabel protected by a 63A D rated mcb , for 3 phase motor circuit .
I desided to derate the mcb to a 50A but it triipped when ther motor was running .
So i then desided to upgrade the cable to a 10mm SWA to take the 63A mcb rating .
BUT IT TRIPPED !!
Strange thing is the 63 A MCB tripps when using the 10mm cable , but not when using the 6mm cable ????
I have even tried a different brand/length of cable and the same happens .
Everyone in the game i ask has never come accross this happening before , so i thought id give it a try on here ? :dizzy2:
Jeff
should it not be the o/l unit on the starter that trips first for overcurrent, not the mcb? Have you ensured any of the integrity of the terminal studs/cable (or whatever) has not been damaged/inside the motor connection box. The motor could just be on its way out with an insulation fault? Looking at possible reasons for mcb tripping...
I will put the amp clamp on to see what exactly its pulling on start up , and i dont think it has a starter on it , but maybe it needs one .
Also, check whether it is wired as star or delta configuration so you can read the correct rating off the motor plate, then set your o/l to this.
I would do a full insulation/resistance test on the motor before anything else tbh. Tripping an mcb with a much higher rating than the motor sounds more like a fault than overload if you are using a D type. As suggested, if it meggers out ok, stick a clamp meter on each phase as it could even be unbalanced.
A lot of shots in the dark here.... the first question is what size Kw is the motor and is it a star/delta motor?, how is it connected if its as suggested 'Direct on Line', what is the length of cable run to the motor and installation method.
Answer these questions and im pretty sure i can tell you why and what and how to solve it.
Mcb tripping etc means nothing and dosn't imply faulty motor until you know what size Mcb should be covering this motor so first thing first before everyone confuses you with random ideas..... What size is the motor and what is it doing as a workload.
Reply to Strange fault - larger cable tripps mcb ????? Why ??? in the UK Electrical Forum area at ElectriciansForums.net
