Strange fault on lighting circuit | on ElectriciansForums
Discuss Strange fault on lighting circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Mark.W
Swindon, Wilts
Evening Chaps
I was wondering if one of you lads could please share some knowledge on this type of fault.
I went round to look at a lighting fault today. The lighting circuit is tripping the RCD.
I did an IR test and the results came back well over 200M Ohms. The neutral is in the correct Neutral bar. My initial thought was that it was a shared Neutral but this has only just started happening.
Cheers
Mark
Had the same myself a couple of weeks ago circuit was ok turned out to be the workings of a fluorescent light swapped it no problems since.
Chris
Yeah...control gear in old fluo's are renowned for breaking down and causing an RCD to trip.
Other than that did you IR test with light switches in both positions??? could be a fault on S/W or strappers.
O/S lights....
Reply to Strange fault on lighting circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
I misread it.
