Strange voltage readings - broken earth | on ElectriciansForums
Discuss Strange voltage readings - broken earth in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
Was fixing a broken twin florescent fitting today and came across something I couldn't work out.
First thing I did was measure the incoming voltage. At the fitting I measured L-E =190, N-E = 90v.
Scratched my head for a minute until I realized the Earth's coming in from the numerous (4) twin and Earth's didn't look right.
3 cpcs we're in a terminal block and the other cpc was direct into the fitting. I decided to try L-E at the terminal block and got 240v.
I sorted the wiring out so all the Earth's were in the fitting properly and all is good. However, I can't seem to grasp why the off readings. I was effectively measuring L-E (just the single cpc from a single t+e) when I got the odd readings but 240 when measured with the other Earth's.
Only thing I can think is either the single cpc was not connected to earth properly (poor connection) ??
Thoughts
Reply to Strange voltage readings - broken earth in the UK Electrical Forum area at ElectriciansForums.net
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
