I done alot of parking lot luminaires and if ballast or ingitors is not working after a simple lamp repalce I just swap the whole kit in and be done with it due most parking lot luminaire are mounted pretty high 10 to 15 meter up typically recentally before I went to France the last one I done is replace 70 lamps , 18 ballasts all of them wired at 277 volts triphase supply to handle the whole lot.
that lot took me most of nite to replace all of the lamps { the reason due the parking lot is empty so I can move quicker instead of jocking around with parked cars which I hate the most }
Merci,Marc
