T
Trulyshocking
Evening chaps :smiley2:
I have another conundrum i'd like to share!!
I have a task to install a new supply to a set of 6 streetlight columns as the old supply is 50 year old PILC and has insulation resistance faults that are beyond all hope!! The 6 columns are already installed with 4mm SWA and have an R1 + R2 of 2.3ohms. The length of run between them is approx 200M. The new supply up to the first column which i'm considering installing is about 150M which i've worked out needs to be 16mm to account for volt drop (for lighting 3%) and the 0.9 factor for being buried some of the way, but this figure only works if the total circuit load was all at the first column... which it obviously isnt! The problem is that I'm gonna be over my max Zs by the time the circuit is installed. Theres no way to increase the conductor size on the existing part of the circuit, so the best way will be to protect the circuit by way of an RCBO. The problem is that I'm not comfortable designing a circuit that has to have an RCD because the EFLI is crap!! We have a spark on site at the moment who has been working on the county streetlight division for a number of years, who says that on the council contract, anything below a Zs of 13 Ohms is acceptable, and of course no RCD's used there!! Are there different regulations covering streetlight installations that anyone knows of?? BS7671 has rules surrounding street furniture but certainly no exemptions that I can find regards Max Zs's! Any help appreciated :cheesy:
