Strip lights. Connecting sections together | on ElectriciansForums
Discuss Strip lights. Connecting sections together in the UK Electrical Forum area at ElectriciansForums.net
London
Excuse a basic question. But just wondering on people's suggestions for installing LED strip lights under cabinets attached. On both the left and right cabinets there is an existing light. Guy wants replaced with strip lights. There will be three sections, one for left side and two for right side, either side of the microwave. Have never installed strip lights and wondering how I do it as neat as possible. I will have to install a transformer on either side and also link the two sections on right. I have seen examples where they have linked two sections by welding. Is there a decent kit could use instead. Or how would others go about doing a neat job with it. Cheers
  • [ElectriciansForums.net] Strip lights. Connecting sections together
By welding do you mean soldering connections or welding the aluminium profile?
Soldering. So thinking it would maybe be transformer inside the cabinet, this then connects to first strip and then solder cable of other end and then wire this up and round back of cabinet and solder onto other section of strip. Probably not seeing something completely obvious and gotta be easier solution to this
Some brands of led tape come with joint pieces, right angles etc.
Personally I solder. One less thing to keep in stock.
[automerge]1589050419[/automerge]
Again, mine at home to give an idea. The 2 flexes go to the driver via a joint box.
It's a bit rough but it's mine and done in a hurry.
  • SC3.pdf
  • SC 2.pdf
  • strip corner.pdf
Nice job mate ? soldering might be way to go. Found the sort of thing would do job but In 2.5metres worth so alot of cable to lose LED Extension Cable with Connectors 2.5m - https://www.toolstation.com/led-extension-cable-with-connectors/p41717?store=A9&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=CjwKCAjwqdn1BRBREiwAEbZcR44J9GSNOf395HMG0NZgoH1fbHPzDkcTpZOPRzhv_c1Fkde8NQo1HhoCPDYQAvD_BwE
Just done our lights in kitchen,got from Amazon,Rgb app controlled & Alexa.
Took me quite a while to install,looks ok for the price.
Used Cat 6 to bridge cabinets,connections were a pain to be fair.
Trying to upload a pic,but comes up with uploaded file was not an image expected,any ideas on that
site can'tupload pics at the mo. you could convert to pdf and upload, or upload pics to a host, then post link.
seealso thread on 10 sockets broken. this was posted there.
Thanks will try
N
How did you make the connections between the strips Cliffed. Was it Cat 5 and soldered?
I've used those strips before, but don't like them; too fiddly, and the higher wattage ones can't dissipate the heat well enough. I use mains voltage linkable led strip lights now, much brighter, more reliable, and easier to install. Search for Knightsbridge LED linkable, available in 3000k and 4000k.
Reply to Strip lights. Connecting sections together in the UK Electrical Forum area at ElectriciansForums.net
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
hI Gent's. I I can explain this spur line briefly, maybe someone can help me? Everything is Spur, no rings. Inside of the house and main fuse...
