N
nrbspark
I am assessing a job in the morning for new works in a pre-fabricated garage. As most of you will be aware these buildings are a nightmare to work on at the best of times. I will be quoting for lighting and small power but have been led to believe that the ceiling is supported by a light steel frame work ( 50mm angle bar ) and I am in 2 minds whether this is classed a structural steel and if it requires an earth running to it from the MET. This would give a 2nd issue of parallel earth paths as the garage supply is only going to be 4.0mm 20 amp with only a 1.5mm cpc which I believe is too small csa to earth the structural steel (if required). Any suggestions guys?
