student property | on ElectriciansForums
Discuss student property in the Australia area at ElectriciansForums.net
hi guys
i have a friend with a 3 storey victorian townhouse which is to be let out to students. It also has an annex at the back, attached to the house but rented out seperately. I am trying to find out what she legally has to have installed to meet requirements. I am putting interlinked smoke/heat detectors throughout but am not sure about emergency lighting etc. A letting agent said it is classed as an HMO but the council say its not. any ideas?!
Outside of electrical, it would also need fire doors, fire extinguishers, fire blankets and an emergency exit for the third floor.
Your best bet would be to speak to the dept in the uni dealing with accommodation. They're normally pretty clued up and you can get a letter from them indicating that the property meets all the health and safety requirements.
HMOs certainly have a lot of rules and regs attached to them - fairly certain they need a licence as well from the council. Not the sort of thing you can just do on a whim - they need a lot of thought.
Em Lighting and Fire detection is a must, also the escape routes and doors will need to be fire rated with smoke seals and intumescent strip in door frames.Heavy Fine I think if not complied with.
Intumescent smoke seal can be fitted to the doors which is easier than fitting to existing frames also the doors will need fire rated hinges, locks and closers. When you look at the HMO requirements it can be quite daunting but having done one recently It's just two weeks hard graft to do the lot
thanks for the replies, whats a 5839 part 1 alarm?
BS 5839, google it and it will tell you all you need to know about fire alarm grades, requirements, the lot. The last time i did a HMO i rang the HMO dept of the local council, spoke to the local Fire Brigade and acted on the advice given by those bodies. This is one part of Electrickery you cant afford to get wrong, cos if you do, then guess where all the brown stuff is gonna land, it may also earn you an all inclusive stay at one of her majesties hotels for a period of time.
Cheers.............Howard
Reply to student property in the Australia area at ElectriciansForums.net
