stupid ducting question.... | on ElectriciansForums
Discuss stupid ducting question.... in the UK Electrical Forum area at ElectriciansForums.net
Ruislip
Probably a silly question... Just wondered what the difference is between insulated and acoustic insulated flexi duct?
Insulated duct can be rigid/semi or flex and is usually wrapped In insulation with an aluminium foil cover over it.
Acoustic is semi rigid and is perforated to reduce the turbulence and thus the noise within the ventilation system. It's also usually insulated a well
Reply to stupid ducting question.... in the UK Electrical Forum area at ElectriciansForums.net
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
Hi I am soon to take the AM2. A friend of mine who just took, said the following items are prefilled in the test schedule. Is it true? - Type...
