Sub main protection??????? | on ElectriciansForums
Discuss Sub main protection??????? in the UK Electrical Forum area at ElectriciansForums.net
E
energizedelec
Ok so western power have put in a new supply 100a cut out fuse and a 100A isolater for me to connect into. Im running a 10mtr 25mm 3 core swa into a loft space and down to a consumer unit. my question is do i need to protect the submain with a switch fuse or can it go straight into the 100a isolater??
Problem is the ones iv read are not clear enough! Am i correct in saying i don't need to install a switchfuse and an isolator is fine as long as the cable is equivalent to the incoming fuse rate?
Reply to Sub main protection??????? in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
totally agree
