J
jimmyjazz
Hi All,
Think I know the answer but just looking for other options....I have been asked to install sub main 60 amp isolation switch supplying already installed 16mm T & E under floor to RCD protected consumer unit. Approx. 2 mtr of 16mm is in wall. I understand that regs require RCD protection for cable in wall, but I am trying to avoid loosing all circuits in event of trip. Would this also apply for meter tails from cut out passing through/up walls? Any ideas?
