sub main | on ElectriciansForums
Discuss sub main in the UK Electrical Forum area at ElectriciansForums.net
J
jimjamjimajam
Hi guys. Can't find anything in the regs and can't think of any reason why it wouldn't be acceptable but is there a reg that states a sub main cannot be supplied from another sub main inline of the origin?
Thanks in advance
Discrimination!.... depends on the protective devices and the ocpd's used in the final submain... will a S/C be just as likely to take out the Submain fuse as it would the final circuit.
So any mcb - mcb combination would not meet discrimination albiet you may achieve it between a 63amp and a 6amp but only partial for any other combinations.
Reply to sub main in the UK Electrical Forum area at ElectriciansForums.net
I really can't see a problem with it assuming there is a neutral there.
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
