sparkyz21
ok so altered sub main feeding annex to commence building work for an extension. the sub main is 10mm T&E with my altered bit swa outside cleated temporarly. so gota do sub main permantely and i think best way is to run sub main again from house fuseboard. so main earth has to be 16mm, or do i use earth stake? also what do i do about discrimination between rcds as i can't put the whole lot on 1 rcd at house fusboard as that doesn't comply neither. any help appreciated cheers jay.
