Sub mains supply wiring | on ElectriciansForums
Discuss Sub mains supply wiring in the UK Electrical Forum area at ElectriciansForums.net
Falkirk
We currently have a property being split into 2 No. flats.
The local electricity board have put the 2 No. meters and consumer isolators external at ground floor level within a housing.
My question is can we run the upstairs flat sub mains supply (SWA) through the ground floor flat to the first floor flat or does this have to be external?
Reply to Sub mains supply wiring in the UK Electrical Forum area at ElectriciansForums.net
No, that is part of a different earthing system, don't mix the different earthing systems unless you have given proper engineering consideration...
davesparks
OP - is this T&E run on the surface or in conduit all the way? Or is any of it below the surface? I'm guessing not as you were talking about...
