subpanel | on ElectriciansForums
Discuss subpanel in the UK Electrical Forum area at ElectriciansForums.net
You can post it here - BUT be aware that the forum moderators are quite conscientious about not allowing advice on projects that are likely unsafe for DIY implementation.
A replacement panel/CU is in that category.
So if you want some advice to help decide what options you have or what a professional electrician has advised then it is OK, but if you are looking for some sort of step by step guide it will be stopped.
Reply to subpanel in the UK Electrical Forum area at ElectriciansForums.net
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
It all depends on the rating of the panel like 60 amp or 125 amp panels. You can never exceed the rating of the panel so having said that you can...
