T
TF and the wire
We have a couple of automatic transfer cars at work that have a SICK PLS scanner on each end, which are connected to a LSI unit that contains the configuration and field details. When it goes wrong, it's a pain usually ending up with it by-passed until I can get to it at weekend.
I want to build a test rig where I can try each component on the bench in my own time. Apart from the two PLS's, the LSI has a number of inputs that I can connect via toggle switches, the outputs can be connected to lights to show their status. But there are also two encoder inputs, each with two channels 90 degrees apart. These are used to provide a speed signal so that the field changes depending how fast the car is travelling.
Anyone know of a good substitute for these encoders. Perhaps a 555 type circuit. How do I get another signal exactly 90 degrees apart? Is there anything on the shelf available?
