I am trying to design an emergency prototype opensource air purification unit for use in hospitals. I bought 4 Osram G23 HNS S 9 Watt Puritec Germicidal Ultraviolet Lamps bulbs and bulb holders Vossloh Schwabe 35006 PL 5,7,9,11W G23 TCS 2pin lampholder - bulb and lamps fit, but I can not find a recommended ballast device for these bulbs.
Please could someone tell me which ballast system is needed, as I don't dabble in domestic electronics very often.
About my project
Hospitals control infectious disease with negative pressure side rooms, however now we have entered a pandemic with COVID19 there are not enough side rooms to go around, or enough masks. My idea is to try to make a "Flu Hood", which will operate in the same way as a cooker hood. The "Flu Hood" which will consist of a light A frame covered in a plastic sheet will be suspended over a patients bed and it will hoover up all the air in the vicinity of the patient. The air is then passed through ducting into a UV sterilisation chamber, which will deactivate any virus particles from the patients breath, before returning the air to the ward.
About my project
