Suitable RCCB replacent | on ElectriciansForums
Discuss Suitable RCCB replacent in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
I need to replace this old RCCB with a suitable replacement.
Currently the one installed is not tripping on test and from the test point. Changing the entire consumer unit is not financially viable for the home owner at present so I would like to change this to at least reinstate RCD protection.
Any help would be appreciated
Nothing else will fit but a Sq D / Schneider of that type.
It's a unique fitting to the bus bars.
Just a note, Schneider changed all the part numbers for the old Sq D stock
QO200RCDX30 will be something else now as the replacement for the clip in type is a din rail type with an adapter.
is that faulty RCD an upfront device, doubling as a main switch? if so fit a stand alone RCD (any brand) In the tails fron the meter.
a secondary concern is that you might have a N-E fault.try testing with the outgoing cables removed.
No its protecting only part of the installation. A split load board.
If there was a N-E fault then the rcd should do its job. If it's not tripping then the rccb is still faulty. There was a good Zs reading on the circuit and no odd voltages across N-E.
That's how I understand it...
a N-E fault on a circuit may inhibit the RCD from operating, both on testing with MFT and the test button. had it a couple of times. once was on an immersion heater cable with a nail in it. once i had dissed the cable from the board, the RCD worked perfectly. on testing the cable, it was a dead short N-E so there was no volts N-E either.
I'll be honest, I dont get that. Iv had rcds that wont hold in because there is a neutral to earth short.
What neutral to earth characteristics would denote an rcd tripping and an rcd not operating at all? Earthing arrangement? Extent of short circuit?
Had that too. A bit of head scratching went on before I realised what it was. Disconnected circuit and RCD was fine.
it's weird. i can't explain the science behind it, but it does sometimes occur.
How odd, taking into account the theory behind rcds, any neutral to earth should operate the device. I cant imagine any condition where the rcd would not see an imbalance when neutral and earth are shorted in some way....
I think by process of elimination I will still try what you have suggested and rule out neutral to earth fault
Reply to Suitable RCCB replacent in the UK Electrical Forum area at ElectriciansForums.net
Our house in a row was built in 1971 and we have metric cables with cpcs for the lighting, top of the row imperial and no cpcs.
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
