G
Gavin Cotton
Afternoon Guys and Girls,
Was going to post this to the DIY section but it wouldn't let me.
Firstly, whilst I will be doing the first fix for this I will be getting a sparks in to test and inspect everything once it's ready, but I do want to have everything in place.
Current setup is a 32amp mcb inside the CU inside the house with SWA (tacked to the surface, not in the ground) running under the house (house is raised as built on flood plain, accessed via flood grate) with the cable then running circa. 1m up the outside wall into an IP rated CU. IP CU has 40a RCD, 1 x 32a mcb and 1 x 6a mcb. This was originally installed to run a hot-tub and 1 string of external laterns. (like large fairy lights, with about 6 on the string).
The plan. move the IP rated CU from the outside wall and install into the inside of the summer house. The SWA would be extended (using an IP rated and potted JB). The 6a would be used to run 2 no. 150w 24v PSU for the LED lighting, total of 4a (if that) on the 230 side and the 32a used for ring main inside the summer house. (there will be a number of sockets, powering a laptop, various NAS drives, routers, telephone and a coffee machine, possibly a small instant water heater, just for rinsing some cups out, will be the lowest wattage unit I can find, oh also a 500w heater.) Far less than whats currently running on the 32a ring downstairs inside the house. So I'm not concerned about the loading on this.
My main question really, the IP CU, as mentioned above, is currently run off of a 32a mcb in the house CU. This 32a has a lower rating than the 40a RCD inside the IPCU
1. Should the 32a mcb in the house be swapped for a 40a?
2. Anything else that screams out a massive 'woo there mary'?
Thanks in advance
Thanks in advance
