sunbed shop wiring | on ElectriciansForums
Discuss sunbed shop wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
O
oggie
hi all, not sure if im in the right bit here but....need some advice im wiring in 2 sunbeds (250w) for a shop thats being converted into a salon.
due to the load im assuming each sunbed needs to be on its own circuit with breaker, will 40a suffice? with a 100 ma rcd?
as for the cable, 10 mm t+e, is that enough to carry the load?
am i missing anything, ive been out of work with a back injury for sometime and im drawing a blank on this!!
any advice would be appreciated
Reply to sunbed shop wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
