Sunlight activated switch | on ElectriciansForums
Discuss Sunlight activated switch in the Talk Electrician area at ElectriciansForums.net
swimr
Does anyone have any ideas where I can get a simple automatic switch that is sensitive to when the sun is shining?
I have a d.i.y swimming pool with black pipe solar collector, It is hard for me to estimate what the days weather is gonna be like before I go off and work. A simple automatic switch that was sensitive to the sunshine would solve the problem by running the pump ony when its hot...
I can buy more complicated systems that switch the pump on when the water in the collector is hot, however these cost ÂŁ400 plus and I can't justify that price..
many thanks
Hi ,Why not just use a temp controler and a thermocouple.,you can set it up however you like then .and for a lot less than 400 quid
atvbitwww
do few market search, there are lot of bits and pieces available in the market for lot less than 50$.
Temperature sensitive switchn light sensitive switch, pressure switch etc.
bit of technical thinking can do some assembling to get what you want
Reply to Sunlight activated switch in the Talk Electrician area at ElectriciansForums.net
