Sunny boy inverter for wind? | on ElectriciansForums
Discuss Sunny boy inverter for wind? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Colin33
Cornwall
I have an old sunnyboy 1700 and I'm trying to connect it to a 1kw wind turbine. I've been told that if I can get into the inverter software to change parameters (mppt) then it may well work. Has anyone any experience of this, or does anyone know where I can obtain a usb cable/interface for the job?
Reply to Sunny boy inverter for wind? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi KungFu Turkey Leg and Mainline Thanks for the link Mainline I will see if they are any help. KungFuTurkeyLeg, as far as I can see the mppt...
This is solved. Praise elder gods. I didn't touch the parameters any more but added a small 120 ohm resistor to potentiometer. The tiny control...
