M
mac1
Hi, when using sunny design for the following set up the sanyo HIT-240HDE4 output less than 240 watt phono solar PS240M-20U modules, the sanyo modules are clearly more efficient am I doing anything wrong??
location Birmingham
Azimuth 0 deg
Inclination 30 deg
PV modules 2 x 8 total 16
Inverter SB 4000-20
Sanyo Annual yield 3299.70kWh
Phono solar Annual yield 3328.20kWh
Any ideas ?? this can't be correct the sanyo modules should output more.
location Birmingham
Azimuth 0 deg
Inclination 30 deg
Inverter SB 4000-20
