SunnyBoy 2000HF with 3.36Kw 14 panel string | on ElectriciansForums
Discuss SunnyBoy 2000HF with 3.36Kw 14 panel string in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
mikeh0512
Hello,
A friend of mine has just had a 14 panel 3.36kW system installed. When he described it to me I was surprised
that the installed inverter ( Sunnyboy 2000HF ) was only rated for 2kW. Is this normal or even correct ?
Many thanks
Mike
Reply to SunnyBoy 2000HF with 3.36Kw 14 panel string in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
