Had a call and the following email from a friend in installing in the Weymouth area called out to a property today. We are a fair bit further to the West and have also had to repair a system done by this company (now bust).
So how do you get hold of an obsolete module from an obsolete manufacturer? Does anyone have one hidden away in a warehouse or know of a wholesaler that might have one?
'The installer was Microgen Southwest t/a HW Smith. The house location was Portland (one of the UK's most likely locations to be hit by severe weather) and the installation was done in April 2011. The company had issued a 2 year warranty.
The module was fitted to a rosemary tiled roof with 600mm BC trusses. The anchors (schuco tile anchors) were at 1200mm and a BP160s rail used. The rail extends approx 300mm past the last anchor.
The home owner said that during windy weather, she could hear something banging and this had been going on for some time, but she did not think it was a module. However since the module came off and landed in her garden, the banging noise has stopped.
Anyone got a Suntech STP190S-24/AD+ module.'
I have some suntech's in the warehouse whether they are the right module I'm not sure. Will check tomorrow for you.
Thanks guys.
Worth mentioning i think that this is the first panel i've heard of coming off in all the bad storms over the past few months and looks to be installer related rather than mounting system failure.
segen have some discontinued 190's that are probably pretty much identical, worth checking the specs - think it was JEtion they have.
South West
Suntech STP190S-24/AD+ module blown away, need a replacement...
Thread Tags
Energetic,
Gavin A,
