Supplier fuse | on ElectriciansForums
Discuss Supplier fuse in the Australia area at ElectriciansForums.net
W
waynelester
Hi,can anyone help,im trying to identify the supplier fuse in a domestic installation.alli can make out is british electric fuse type 228 tr 40,im assuming the 40 is the rating 40a,this to me seems very low,can this be right and how you you go about getting it increased,any advice greatly appreciated
To get it increased you will have to contact your supplier and request an Increase in electricity supply. they will send you an application form which you will need to complete as you are the Electrical Contractor. Fill in and return. Job done.
Reply to Supplier fuse in the Australia area at ElectriciansForums.net
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
