suppliers neutral size | on ElectriciansForums
Discuss suppliers neutral size in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ruislip
I work in a lot of big old townhouses that are converted into flats. Many of them have a 3 phase head at the intake (3x 100A fuses) which makes me think the suppliers neutral must be quite substantial?? I have always assumed it is <35mm when selecting main bonding conductors but thinking about it, could it be bigger? Your thoughts would be appreciated!
Worst case scenario (only one phase of three being utilised) the neutral is never going to need to be bigger than 25mm with a 100A main head.
Some of these houses are converted into between 3 and 6 flats, so often each main fuse will supply 2 flats plus a landlords supply as well. Rarely is only of the fuses utilized.
The primary function and only function of the neutral in a three phase system is to carry away out of balance current.
ok so that's correct, but say this 3 phase installation has been converted to single phase loads only, surely that neutral conductor is now underrated ?
Reply to suppliers neutral size in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
