A
alisyed1
Hi,
Have a problem and not sure what to do next. I went to isolate my consumer unit to change the entire unit in my flat.There is an isolator fitted before the consumer unit, as the supply fuses are not within the premises. The supply cables connect straight into the meter in the premises, the main protective earth connects onto the metal conduit that the supply cables are in using an earth clamp. I have traced the cables back to what I assume are the fuses in a metal enclosure in the communal corridor. The enclosure has a lock on it.
The problem is that the isolator does not function as intended. I cant get the isolator contacts to open, tried flicking the switch a hundred times. Checked for external signs of damage on the isolator. What should I do? Should I contact my supplier to replace the isolator as it has stopped functioning, will they do this for free as there is no fuses within the premises that can be removed. Or should I change the isolator myself? All help will be greatly appreciated.
