dml
hi, looking to bring supply to a newly built garage, have 6mm run from the outside meter box with main switch in it to the garage, goin to put rcd protected CU in garage and wire my lights and sockets.
Problem is i cant get 6mm into house and was enquiring if it is ok to run supply from here..... going to split cables after main switch into henley block and go to house and garage from the henley block... Is this ok to do this
