Supply Fuse RH 60 | on ElectriciansForums
Discuss Supply Fuse RH 60 in the Talk Electrician area at ElectriciansForums.net
Hi Just need some clarification, looking at a supply fuse, and says on it BS 88 (1959) and also BS1361. (1971) and then in BOLD RH60
Its 60 amp but iam thinking its BS1361 as thats the latest date out of two stated on the fuse.
any thoughts.....? Why it state two types on there
now, what does one put on a cert . for that, then. ok, it's now BS88-3, but i prefer to enter what it says on the actual fuse. ( assuming, of course, that the seal has fallen off at some time in the past )
If it says BS1361 then I'd enter that on the certificate.
Reply to Supply Fuse RH 60 in the Talk Electrician area at ElectriciansForums.net
Grid limit is now import limit.
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
