Supply protective device? | on ElectriciansForums
Discuss Supply protective device? in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Hi Guys, when filling in this part of the form on an industrial EICR, would I have to contact the DNO for this info as the fuses are on the pole outside the sub station? Cheers
Reply to Supply protective device? in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
