L
LlandrilloSpark
Guys
Inspection i did about two weeks ago and im going back to do the remedial work tomorrow, next to the main ccu there is a one module unit plus 61008 rcd main switch, inside the unit is a 32A MCB protecting an armoured outside supply, the module unit is fed by 6mm single spured of the incoming side of the main switch in the main ccu.
my query is - should the tails theoretically be 16mm to match the main 60amp cut out fuse as technically this is a supply split, or are the little 6mm tails protected by the 32A mcb only allowing that much current to flow?
I see a lot of this and wanted other peopled opinion on it, personally i always put in henleys and split it correctly
cheers
cheers
