Signum
Hi all
First time posting so hello!
We have been asked to supply and install a Wall mounted gas heater/blower for a warehouse, (well 2 in fact, warehouse and workshop)
We have it all in hand, got heater's arranged, gas safe sub contractor to connect and commission gas, but on our side im struggling to find what is required from a regulation point of view for gas heaters.
It will be a single phase 10 amp supply run in SWA, pus a 10mm bond to gas that is being fitted. Now i would assume from lateral thinking that i bring a supply from the DB to each heater, then provide a rotary isolator next to each unit as a 'maintenance switch', and then a emergency stop button at low level. (the units have little control pads for operation)
Would this suffice, where can i find out more, or maybe one or more of you could help me.
Thanks in advance
Mark
Thanks in advance
Mark
