G
gregmac
hi
first post
i went to look at a job tonight. the isolator for the house is outside on the garage around 12metres away from cu. the supply needs changed as it is joined onto a 10mm t&e which isnt a pretty joint.
the house is a 3 bed bungalow. what size of swa would you recommened to run in? i was thinking of glanding it into an enclosure and having henley blocks inside it with 25mm tails coming out of it?
also i done a ze on the property at the isolator and there is on earth. which means i will need to make it a tt system.
i have never done an earth spike before as i am not long time served. i was going to put the spike outside the property in an appropriate enclosure.. what size of earth from the spike to the cu would i need to run?
could someone give me some advicde on how they would tackle this please
would be much appreciated
first post
