Supply Voltage | on ElectriciansForums
Discuss Supply Voltage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
EddieB
Hi All
I was out in the sticks the other day at a pig farm and was looking at a couple of faulty sockets in an accomodation block when I did a voltage check the voltage would fluctuate between 205 and 218v this is the first time I've seen this. Any ideas and is it a problem. I checked back at the head and it was the same there
out in the sticks this is a common problem, usually caused by volt drop when the demand from neighbours is heavy
just think of several houses supplied by a couple of miles of 80 year old 16mm cable. was ok before electric washing machines came out.
Reply to Supply Voltage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all. OK... Let me just try and clear a 1" square space on the screen inbetween all the highly intrusive ads.... On a site (NHS in fact) and...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
