was asked the other day about main supply, the bloke is splitting his house into flats and wants to keep it on the one supply. he will then fit coin meters for each flat, both flats will have a electric cooker.
Put in a landlords supply I.e distribution board for flat supply and hall and stair lighting and limit the load to the flats. He can always ask the DNO to upgrade his supply (I doubt he will)
mcm, for me it would be a no, IMO too many items of heavy current use. you could have a scenario with 2 ovens, hob & shower on the go all at once. Add in a kettle and an iron you could be blowing service fuse.
You could use a 60Amp switch fuse for each flat but again with the loading you could be popping those, would advise your client to try and reduce loading on the installation.
