T
Trevor R
Hi
Just looked at a job in a 90 year old building - the customer wants a number of additional sockets, the only existing socket is surface mounted with the T&E chased into the wall. The room full of bookshelves all walls from the floor to the ceiling. I explained that to chase the walls etc would mean moving all of the books, and not without a little dust and disruption - he said sod that surface mount them using trunking make it look as neat as you can.
So I am thinking I can extend from the existing ring - but how do I make bring the T&E out from the existing surface mounted socket look neat? Cable out and into trunking?
Any ideas more than appreciated
Trev
Oopps that will teach me to check what I have written - the existing socket is flush mounted not surface - the new sockets will be surface mounted any ideas on how to make that look neat?
Drill out the thread on a surface box and use extra long 3.5mm screws through the holes in the surface mount box and into the recessed one, then mini trunking out of the socket, which will make all the sockets look the same.
Surface Mounted sockets
Australia
Trevor R,
ipf,
