Hi,
I recently upgraded my home panel to a Square D qo panel. I had a Siemens FS140 whole home surge protection installed in the first space on a 20 amp double pole breaker. I tend to lose power a lot and get surges from trees on the power lines when it rains.
I have two square D HEPD 50 surge protectors. I am thinking of installing one of these directly on the bus bar as shown below. Will this cause any issues? Is two better than 1 in this situation or am I going to cause them to interfere with each other?
I am also wanting to install the second one on my A/C condenser disconnect. I think I need to set a separate ground rod at the AC disconnect as it looks like the neutral and ground are connected together.
Anyone see any issues with what I am trying to do? Can you install to many surge protectors?
