Surge Protection | on ElectriciansForums
Discuss Surge Protection in the Electrical Tools and Products area at ElectriciansForums.net
deeseejay
Hi,
I have a combi boiler fitted in a local community hall that blew a circuit board due to a power surge last year. This was rectified at the time by the fitting of a new circuit board. The boiler is connected to the electrical supply by means of a switched fused spur.
Does anyone know if there is a surge protected spur on the market that I can replace the existing on with and prevent further problems? I dont want to go down the line of using a plug and socket as users then to pull the plug out and leave it cold for the next person.
Any help will be well appreciated
Reply to Surge Protection in the Electrical Tools and Products area at ElectriciansForums.net
You can get surge-protected 13A plugs such as this...
Thank you for the advice; I did figure it would be in the realms of discovering, say, a 10mm earth cable in a property, and having no more...
