surge protection | on ElectriciansForums
Discuss surge protection in the UK Electrical Forum area at ElectriciansForums.net
durhamspurs
hi
can anyone help me with info on surge protection.
a fire alarm panel supplied via a unswitched fused spur has now twice been affected by power surges causing the printed circuit board to fail
Does anyone know of an unswitched spur incorporating surge protection
regards
john
hi
regards
john
You first need to find out is it surges, what else is on the supply and what blew up on the circuit board? The circuit board should not blow up from spikes on the supply!! What kind of installation is this, how is it earthed, how big is the building and what other loads are attached to the supply. IF you think it is surges, or wish to survey for them hire or purchase one of these http://www.fluke.com/fluke/uken/Electrical-Test-Tools/Power-Quality-Tools/Fluke-VR1710.htm put it in a big plastic adaptable box next to the fire alarm and use an additonal fuse spur to power it, it has a male IEC plug on it so you will need to get an IEC female lead, cpc.farnell.com and others will help. Once you have some more data and think it is big surges then you can get kit from ABB that can be din rail mounted and has alarm contacts if the surge protection is overloaded...
Reply to surge protection in the UK Electrical Forum area at ElectriciansForums.net
Thank you for the advice; I did figure it would be in the realms of discovering, say, a 10mm earth cable in a property, and having no more...
You need a CT clamp at main tails, it depends on the rules where you are - you used to be allowed wireliss ones (such as MyEnergi Harvi), these...
