Was working at a HMO house that's being renovated bit by bit. The work has been started by another spark and I've been drafted in to help. The other spark has wired sub mains, wired in 16mm 3c Swa with a seperate 10mm earth run with it. I've rewired the lights in one apartment and the sockets have been rewired by the other spark. I need to provide a certificate for the letting agent (the other spark lives down south) so a tenant can move in. Firstly what certificate should I issue? EIC or EICR? Obviously I'm certifying my own work (lights) and work done by others(sockets and sub main). The other spark has tested his own work and sent me the results but I have re-tested it as it's me who's doing the cert.
Secondly what size should I put for the cpc for the sub main, 16mm or 16mm + 10mm = 26mm?
Hopefully this makes sense!!
