B
brizospark
Does the steel wire armour have to be earthed in ALL cases?
Discuss Swa armour earthing in the Australia area at ElectriciansForums.net
Also should SWA earth tags be fitted in ALL cases?
what if for instance there is a cpc in the SWA, at the DB end earth tag with fly lead connected to earth terminal. Other end metal socket. Is it a reportable fault if no SWA earth tag at this end?
Reply to Swa armour earthing in the Australia area at ElectriciansForums.net
