Simon_
I'm about to do my first job with SWA cable installing a socket in a shed under a metre from the house. CU is an old wylex CU which was upgraded with RCD protection when the guy had a new kitchen fitted. Would I be ok with the following...
2.5mm t/e to wiska junction box from 30A JB in bungalow loft
2.5mm 3 core SWA from JB with black as cpc to earth bar in box to shed FCU
2.5 t/e to socket
Do I need to connect the banjo tag if the earths are connected together? What size cpc should I use if I need the banjo tag?
2.5 t/e to socket
