Sparkman123
Hi Guys,
I would like to install power in my detached garage and was wondering what the correct type/size of SWA cable/glanding/steel junction boxes if needed etc. I would need to connect it between the House CU and a garage CU via SWA cable buried under lawn.The distance involved from house CU to intended garage CU is approx 12mtr. I was intending to use the spare ways on the 30 mA RCD side of my house Split Load CU.
The supply would only be for the following :-
1 x Double 13 A Socket
1 x IP 66 Single unswitched 13A outdoor socket
6 x Double 70W Fluorescent light fittings
Note - I do not intend to use any form of welding equipment or other potential heavy loads.
Of particular interest to me is the method of glanding and earthing this install would require.Any help/tips on this greatly appreciated.Thanks.
Cheers,
Sparkman123
Cheers,
Sparkman123
