Not got regs with me. Installing sub-main to detached garage using SWA method "D". Propose using 6mm 3 core SWA cable. From memory takes about 46/48amps. Don"t know about 17th regs..but in the 16th regs were you allowed to add 10% to the tabulated figure given if u/g. Basically I'm trying to find what is the max current that could be carried. The SWA cable will also installed within the house behind the ceiling/insulation. Thanks
