swa calculation | on ElectriciansForums
Discuss swa calculation in the UK Electrical Forum area at ElectriciansForums.net
E
eamonn1983
I need to work out if I will be required to run a separate protective conductor along side the swa cable I'm going to install. The cable is a sub mains feeding a 3 phase db panel in a large workshop. The cable is going to be a 50mm 4core 120 metres steel wire armoured installed in a underground duct. The protective device feeding the cable is a merlin gerin NS250N 160amp 3 phase mccb which and the readings at this end are zs 0.19 and pfc 1.23KA.
I'd be grateful if someone could tell me how I can determine if this needs a separate protective conductor and if so maybe explain the calculation,to help me,in the future.
Thanks in advance
a chart was posted the other day by eng54, showing the armour sizes required to comply as cpc. generally, all SWA cables up to 95mm, the armour is sufficient as cpc. use forum search and you should find it.
Thanks in advance
The table i posted and is being referred too, does not imply compliance for bonding purposes, however, if this large workshop already has it's bonding requirements catered for, from the supply that this sub-main is being taken from, it's all well and good. However, if it were a supply for a stand alone workshop with extraneous services etc, then a full size separate earthing conductor would need to be installed alongside the SWA cable, unless of course you used a 5 core cable, which aren't easy to come by...lol!!
Reply to swa calculation in the UK Electrical Forum area at ElectriciansForums.net
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
