SWA CLEATS IN WOODEN GARDEN SHED | on ElectriciansForums
Discuss SWA CLEATS IN WOODEN GARDEN SHED in the UK Electrical Forum area at ElectriciansForums.net
Lancashire
Is there any requirement or logic to using fire-retardant cable cleats for SWA inside a wooden shed?
There will be a 2 metre vertical run and a 3 metre horizontal run of 4mm 3 core SWA.
Cid's probly right but personally I don't see the point.
It's a wooden shed, if it's on fire then I see no benefit in having fire retardent clips whatsoever. There will be no one alive in it and no one entering.
If the wall which the swa is on is hot enough to melt pvc cleats, then trust me, there is no wall.
Bottom line is , the regs require fire proof fixings to prevent collapse.
As crazy as it seems to fit fire proof fixings to a wooden shed which would just go up like a tinder , just use metal to tick the box.
A bit of bandy will do the job.
Are firefighters going to enter your shed when its on fire and get entangled? No. Just clip it.
These guys might.........
[ElectriciansForums.net] SWA CLEATS IN WOODEN GARDEN SHED
We can fix a consumer unit to wood with the rear entry open for cables to enter, and the massive entry hole doesn't have to be sealed, but some people really think you can't use cleats in a wooden shed as it could be a fire risk. Not sure how many firemen would be going inside a burning shed to save the lawnmower.
The regulations simply state that wiring systems shall be constructed to prevent premature collapse in the event of fire, there is no mention of type of installation....shed....domestic....commercial....industrial. Nor does it say common sense can be applied,it's a blanket requirement no matter how daft it might seem. Hence the disagrees to some of the above posts. If you ignore the requirement it's a departure, your call if you want to justify it on your EIC.
Yeah I can justify it it's absolutely pointless
Reply to SWA CLEATS IN WOODEN GARDEN SHED in the UK Electrical Forum area at ElectriciansForums.net
I hate it when a shed is TTd, why can they not be extended from the tn system? popcorn ready
