Hi,
I need to provide power (about 3 amps) to a tent in a school field for a weeklong event that happens once a year. Up to now the power has been supplied from a 13 amp socket with 2.5mm flex into a 32 Amp command plug and socket, then down a 100 Meter SWA with 3 * 2.5mm cores to another 32 Amp commando connector and on to an extension lead, but the SWA armour is not earthed or clamped in place and it should be.
Can anyone tell me how to connect SWA to a 32 amp commando plug correctly, or give an alternate suggestion for a weather resistant connector that can be unplugged but will convert from SWA to regular flex sing the correct SWA glands?
I hope I have described my problem clearly.
Many Thanks
Paul
Many Thanks
Paul
