Swa csa?? | on ElectriciansForums
Discuss Swa csa?? in the Australia area at ElectriciansForums.net
K
Kevin
OK, sorry to ask what might be an obvious question, but is the csa of the steel wire, forming SWA cable standard for each size of cable?
For example, does a 2.5mm SWA cable have 5mm csa of steel wire, and a 6mm SWA cable have 10mm csa of steel wire, or does it differ between manufacturers?
Does this make sense?
Many thanks
Cheers for the quick reply Lenny.
If I'm reading it correctly, for a 2 core 6mm PVC/SWA/PVC, the csa of the actual steel is 22mm, and the copper equivalent would be 9.75mm??
Kevin
Reply to Swa csa?? in the Australia area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
He can apply for an E7 tariff with or without storage heaters. It depends on his electricity usage profile on whether this is a good idea or not...
